Power Cloner plugin
  • Power Cloner is a R13/14 Cinema 4D plugin that implements a totally new concept of cloner tool.
    Thanks to its design and flexibility it can be used with success in many fields from Motion Graphics to Architectural design.
    The usual limit of the other standard cloner systems is the ability to position and control each single cloned elements. Normally you can position the clones on a surface by selecting a few options like vertex position, surface position, tag selection etc etc. but sometimes it is not so flexible.
    So we thinked that joining the power of a Ray tracing system with a cloning system could be a new way of thinking cloner.....and this is what we have done.
    The principle of use is very easy:
    - use an object and Rays Emitter and project the rays on a polygon
    - you can also control the focus of rays thanks to another object
    - each ray that collides with the polygon becomes a cloned object
    - you can clone any kind of object
    You can use our two special emitter objects called Planar Projector and Dome Projector or you can use all the objects of Cinema 4D that are based on Polygon or Spline (Cube, Sphere, Cylinder, Polygon, Arc, Rectangle, Nside, Spline etc etc)
    Of course we have integrated a lot of options to give you the possibility to control the rays and change clones position, rotation, scale and much more.
    We have also implemented a target modifier that attracts the attention of cloned objects depending on the distance between target object and cloned object.
    Within the plugin bundle it is included also a Spline Cloner that has got the same main powerfull features of the Power Cloner
    http://www.c4dzone.com/en/blog/videob…-plugin-296.htm
    Power Cloner is available at our plugin section store at price of 35,00 euro + VAT
