There are a few options that don't show on some of the materials, for example light cloth's thread count or metal2's fresnel file. Also, some paramters are setup to use Carrara percentage, but really need a much larger value. You can use Carrar's multiply, but a better solution will be addressed later. This build times out end of the month."
Zitat: "Someone noticed that their file saved with an older version did not load in the latest version. This was due to the rapid changes. So here is a build that chould be 99% file/load stable going forward
It adds Lights
- Lux Sky2 - Lux Sun
It adds some LuxRender textures, but I am in the middle of adding those."
Hi, wieder ein neues Build für Win und Mac jeweils 64 Bit.
Spheric Labs schreibt:
"Changes: - All options for materials should now be visible. - All the texures of the 1.0 spec implemented (exception band and multimix) - Added Mac Build. Install/Copy LuxRender such that there is a folder right next to your Extenstions folder called LuxRender that contains the LuxRender application.
Todo: - Bump, Normal, and Displacement maps. - A decent autotranslation - some error checking before handoff to LuxRender. For example, you can plug a float texture into a color slot. - Carrara Instances as LuxRender instances - Various UI and workflow improvements including choosing where LuxRender is."
Hi, wieder ein neues Build für Windows erschienen.
Zitat von SphericLabs:
"Changes: - Added Projection Light. - Bump maps on all the materials that support one. - UI elements for the lights. - IES parameter on the AreaLight. - Gain on AreaLigh. - Users can now choose where LuxRender is. - Fabric (Weave) option on Cloth."
Hi, heute gibt es schon wieder neues, gleich zwei neue Builds sind erschienen.
Erstes Update von heute, Zitat:
"Changes: -> Normal Maps work. Plug a Carrara Normal map into the bumpmap channel (This is the way LuxRender does it). Want a bump and a normal map?, use a Lux Add texture or a Lux Mix texture to combine them.
-> Lux Blackbody now has a temperature for settings the color.
-> Lux Constant Color and Lux Constant Float. This solves the problem of "Some parameters values are too limited". You can use a Constant Color or Float for any spot where you need a much larger value/color or smaller value/color. Volumes are the most common case."
Zweites Build von heute, Zitat:
"Changes: -> Carrara instances as LuxRender instances."
Hi, mittlerweile sind wieder einige neue Builds erschienen, auch für Mac.
Zitat: "Win64 Build - Changes: - Glossy, GlossyTranslucent, Matte, MatteTranslucent will now show the texture/color assigned to them in the preview shader pane. - Fixed Crash when using internally saved textures.
Win64 Build - Changes: - Fixed crash on any object or shading domain that was not assigned a shader.
Mac64 Build - Changes: I have changed when it asks for the LuxRender folder to when Luxus is first chosen as the Renderer. Mac 10.8 did not like the old way (crashed Carrara).
Those using Mac's should run the LuxRender app at least once via Finder before attempting to render. You will almost for sure need to right click -> open to "enable" it through security. OSX will warn you about running application downloaded from the internet, say ok and you should be good."
“Changes: -> Improve Autotranslation. V4 and M4 look halfway decent now. -> The cone angle and angular falloff now work on spot light.
-> Build times out end of May.”
Das angefügte Bild zeigt v4 ohne irgendwelche Änderungen an Shadern etc., einfach aus Runtime geladen und mit Luxrender via Luxus gerendert. Die verbesserte Autotranslation ist seht gut zu erkennen.
Hi, nach einer kleinen Pause sind ein neues Update für Win64 und ein Sample Shader Pack erschienen.
Zitat von Spheric:
"Changes: -> Fixed a non exporting bug when exporting the indoor preset scene. -> Auto convert is changed and support shininess and reflection maps. Please provide feedback on if it's too much orite not enough. -> Preview of Glass2 is now a semitransparent white. Preview of metal2 with color is the shade of the color. -> Render Settings now includes the most common settings. Less common settings can be set through the extra settings field. -> UI tweaks per user feedback."
Nun wird es auch möglich, Animationen per Luxus in LuxRender zu rendern.
Spheric schreibt:
"This enables those the want to render animations. Rendering a movie will cause a series of files to be written using the format of name_001.xls, name_002.xls, etc. Luxus wil not autolaunch LuxRender in this case. You can then manually launch LuxRender and open the file sequence yourself and start your rendering epic."
Hi, vorher und nachher Bilder gibt es einige im DAZ Carrara Forum.
LuxRender rendert unendlich. Wenn Du der Meinung bist, Deine Szene ist für Dich okay, dann brichst Du das Rendering ab. Sobald Du die Szene an Lux übergeben hast, kannst Du auch andere Arbeiten in Carrara erledigen, da das Rendern per LuxRender extern erfolgt. Verwendets Du die Carrara eigene Engine ist Carrara für andere Arbeiten blockiert. LuxRender ja oder nein wird wohl eher eine Glaubensfrage sein. Die Autotranslation funktioniert bei manchem Content sehr gut, hingegen bei anderem Content müssen die Shader manuell angepasst und eingerichtet werden. Dafür sind Lux Texturen und Lux Materialien im Texture Room verfügbar.
