Carrara 5.05 Update
Es gibt 1 Antwort in diesem Thema, welches 2.265 mal aufgerufen wurde. Der letzte Beitrag () ist von wal.
  • Carrara 5.0.5 Update Features and Fixes
    Below you will find a list of bugs that have been fixed:
    General:
    - Carrara's interface freezes
    - Scrollbar not activated by default in Keyboard Shortcut Menu > 3D View >Edit Section of Preferences...
    - Wrong sound panel in properties
    - Memory leaks when playing a movie in loop
    - Need "Apply to Group" Option In Include/Exclude Lighting Feature
    - sequencer: selecting lots of keyframes (eg in a BVH imported file) is extremely slow
    - Dual monitors: vertex modeler, the shading domains list is drawn outside the scrolling area
    - Dual monitors: Windows cannot be moved to the top of the secondary monitor
    - Problem launching Carrara as normal user
    - Application crash when modifying a text with a deformer
    - Smooth Objects Scene command: should not affect volumetric primitives
    - Graph editor: create key frame in the mini-graph doesn't update the ui
    - Matchmoving: importing a Syntheye file referencing a movie with a number of digits different than 3 makes the import fail
    - Duplicated objects will not attach to the bones
    - Error message appears when performing 3D boolean operation with a deformed object
    - Unable to skip unknown primitive
    - Assembly room/Properties Tray/Drag and dropping objects bug
    - Problem with Wacom tablets when moving the camera
    - Master Object, Shader, Sound List: Naming issue
    3DView:
    - When the camera is scaled, the Production frame isn't displayed at the proper place
    - Dolly tool resets Camera scale to 100%
    - The Wire Frames of the active camera are displayed when they should not be.
    - View Selection: should be undoable when applied to a scene camera
    - Surface Replicator: selection in the 3DView should select the surface (and not the replicator)
    - Carrara becomes very slow in textured mode with trees
    - Carrara becomes very slow in textured mode on with Poser figures
    Replicator:
    - Problem with shadows when rendering replicated objects in the batch queue
    - Surface replicator: problem when replicating on an object inside a group
    - Object replicator preview doesn't match the rendered image
    - Carrara hangs after modifying a tree in a replicator in texture mode
    Particles:
    - Forces in particles - transformation of force give unpredictable results
    - Crash in object mode when particle's lifetime can be negative
    - With the "die on impact" and in object mode all particles die when the first one hit something
    - Particle calculations take an abnormally long time after inserting a poser figure
    - Generation rate problem when "Nb particles / s" can become negative because of the error factor
    - Time goes jump back and forward when playing this animation
    Poser Native Importer:
    - CR2 Importer: importing "Suit Jacket.ppz" failed
    - CR2 Importer: animation import from pz2 is not working
    - Problem with the position of eyes
    - Problem when figure parented to another actor
    - Carrara freeze opening this file
    - Error while converting Poser figure to vertex object
    - Problem finding textures
    - Problem when conforming figure (message: incompatible figures)
    - Problem importing "Skeleton Man.crz"
    - Problem with Poser native importer
    TransPoser (Pro Only):
    - Crash when importing a scene containing an IBL light
    - Network Rendering: figures imported with TransPoser are not rendered on the render nodes
    Modeling:
    - Spline Modeler: closing the extrusion path cannot be properly undone
    Rendering:
    - Rendering is very slow when many big objects are in the same location
    - Really slow rendering with replicated trees
    - Slow rendering of Volumetric clouds in some cases.
    - Translucency: problem with alpha channel
    - Indirect lighting does go through transparent objects using alpha channel
    - Memory allocation error while rendering the forest file of the scene Wizard
    - Volumetric clouds: memory allocation error while rendering volumetric clouds
    - Rendering: Problem rendering big cylinders
    - Crash with displacement mapping applied to particles
    - This camera renders the same object in two different places
    - Replicator crash in multi-processor
    - Render performances: every object is rendered twice but at the same place
    - Render Node crashes when rendering a file for the second time
    - Light sphere animates in steps
    - Cylinders are not saved properly.
    - Network Rendering: particles are not rendered the same on main application and render node
    - Problem with Motion blur and particles
    - Render Room: In Named File is not saved !
    - Volumetric clouds have the wrong size in the batch queue or the modeler preview when the units to mile ratio is not the default one.
    - Carrara lock when rendering this file
    - Impossible to render an image in 16000 by 16000 on Windows
    - SMP: Unknown error rendering a scene containing a light with a movie as gel map
    - Freeze while rendering a file with a sky
    Vertex Modeler:
    - Crash when scaling a vertex object
    - Morph Targets lost after copy paste
    - Slow down with Background Images
    - Carrara slows down when using an image for the backdrop
    - Impossible to switch Edit Mode when Weight Painting selected
    - Setting a custom shortcut on some of the commands in the model menu (Crease, Smooth...) sets it on a different command.
    - Using a keyboard shortcut to close the window (while the mouse is inside it) causes display problems.
    - error on converting smoothing with level 0 on modelling
    - 4 view layout,area render stays when clicking in a different view
    - View Selection doesn't work properly
    - Crash when rendering a group of smoothed object
    Shading:
    - Problem with shader selection menu
    - Unstacking a lighting model generates an error
    - Using a terrain distribution shader on a deformed object crashes the preview.
    - Unknown error occurs when dragging and dropping a shader layer.
    - Shader loss when copying an object from a document to another
    - Terrain shader has some transparent parts when there is no transparency in the shader.
    - Problem with Drag and drop shader from browser to preview window in shading room
    - Texture size is limited to 2Gb
    - Error message when cancel "edit shader"
    - Remove Unused Master Shaders can remove shader that have displacement mapping
    Import/Export:
    - 3ds export duplicates textures
    - obj exporter duplicates textures
    - VET Animators: cannot input time...
    - Error when opening this FBX file (same edge used twice in polygon)
    - Crash when opening lwo file from XFrog
    - 3DS importer: shaders names issue
  • Da waren die Eovianer aber ganz schön fleissig ... Hexagon 2 in großen Umfang und nun fast ein "Major"-Update von Carrara ... :D
    Wer benutzt denn von euch Carrara 5 (Pro) und wie gefällt es?
    Gibt es Dinge die super gelöst sind gegenüber dem Vorgänger und gibt es Dinge die noch einer nachrabeit bedürfen?
    Wolfgang
