DAZ Studio 4.5 RC verfügbar
Es gibt 32 Antworten in diesem Thema, welches 5.679 mal aufgerufen wurde. Der letzte Beitrag () ist von mbarnick.
  • Hi
    DAZ Studio 4.5 RC1 verfügbar:
    Link: http://forum.daz3d.com/viewtopic.php?t=190546&sid=ebb94200b4126763f82bf2e4b0875606
    Zitat:
    "New in DAZ Studio 4.5:
    Full implementation of the DSON file format.
    This enables full scene save in a lightweight scene file (DUF format). These scene files can be loaded and used by anyone who has installed the products used in the scene. If one or more of the products is not found upon loading the scene, a warning dialog will indicate which files are needed.
    Selective item save/load.
    Save only selected items in a scene, then drop them into another scene using lightweight preset files.
    Viewport speed dramatically increased.
    For many viewport interactions, speed will be 2-5x faster than DAZ Studio 4.0.
    DSON file save includes the ability to load and use most Poser files as if they were native DSF files.
    DUF scenes that contain items in Poser format are also sharable (i.e. only contain references to the needed Poser files).
    Property Settings now consolidates more information about each property into a single interface (e.g. presentation editor).
    FBX Import
    FBX files can now be round-tripped through DAZ Studio, including rigged and animated items in the scene.
    The Darkside style is now included as part of the base installation package.
    No serial number is required to run either the 32-bit or 64-bit versions of DAZ Studio Standard
    Shader Mixer has significantly improved workflow and documentation.
    New "Ready to Render" scenes have been added as part of the content that installs with 4.5.
    Loading these is a great way to start tweaking and playing with some cool scenes.
    A number of Lesson Strips have been added.
    These are quick lessons about DAZ Studio basics. There are also instruction on how to create your own Lesson Strips on the DAZ Documentation Center."
    rk66.
    Noch nicht ausprobiert, aber ich schätze, du kannst damit dann einzelne Items / bereits geposte Itemgruppen abspeichern und einfach in eine andere Szene laden.
    Beispiel: du hast dir nen Raum gemacht, der schon schön beleuchtet ist, wo ein Sofa zum reinflegeln einlädt und ein nettes, selbst modelliertes Feuerchen (ebenfalls bereits beleuchtet) im Kamin brennt. Du hast aber keine Lust, das zu exportieren als Props, sondern möchtest es einfach als Preset haben.
    Leider passiert es hin und wieder (mir jedenfalls), dass abgespeicherte .daz-Szenen einfach die bestehende Szene überschreiben, wenn man nicht mit "merge with scene" arbeitet. Deswegen gibts jetzt ein neues Format, in dem du dann einfach deine Kuschelszene speicherst, und das Preset damit laden kannst.
    Aber, wie gesagt - alle Angaben ungeladen und ohne Gewehr ;). Ich habs noch nicht ausprobiert.
  • Hi Lessa,
    jou, so oder so ähnlich hatte ich das auch verstanden, nuuuuur.....
    wenn ich bisher einzelne Teile einer Szene weiter verwenden wollte, hatte ich alles nicht brauchbare gelöscht, eine eigene, neue Szene daraus erstellt und dann mit "merge" dorthin, wo gewollt, wieder eingefügt, man kann ja ohnehin nur immer mit einer offenen Szene arbeiten.
    Sollte vllt. so etwas wie die Copy-Funktion in Poser sein? :nachdenklich:
    ...soll heißen?
    ( Also nicht, daß ich es aus dem Englischen nicht übersetzen könnte ;) )
    Gruß RR
  • Ich trau mich nicht. Oder doch?
    Habe gelesen dass GenX nicht funktioniert.
    Wie schauts aus mit Reality und den ganzen Zeug was man für DS4 bisher gekauft hat?
    Immerhin sind die Dateien nicht abwärtskompatibel zu DS4!
    Wie sind denn eure Erfahrungen?
    Geht noch alles oder steht ihr schon vor nem Scherbenhaufen?
    Dieses Thema enthält 24 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind, bitte registrieren Sie sich oder melden Sie sich an um diese lesen zu können.
  • Dieses Thema enthält 24 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind, bitte registrieren Sie sich oder melden Sie sich an um diese lesen zu können.
