Mädchen und Mütze
Es gibt 5 Antworten in diesem Thema, welches 305 mal aufgerufen wurde. Der letzte Beitrag () ist von Licke.
  • Mädchen mit kleid und mädchen mit kleid und mütze, Ich weis die mütze ist ein stielbruch aber die hat schon ihrem Großvater gehört! und weil unser Mädchen zwei Großväter hatte hat sie auch zwei mützen.
    KI Qwen 2512
    Prompt´s
    kleid:
    A sleeveless Gothic Lolita corset mini dress featuring a structured bustier bodice that cinches sharply at the waist before flaring into a voluminous, tiered bell-shaped skirt. The garment is defined by thick shoulder straps and vertical structural side panels that create a rigid silhouette. The back displays deep negative space formed by crisscrossing laces, creating concave recesses between the corset panels where wide black satin ribbons are threaded through silver metal grommets. The skirt exhibits physical layering with horizontal tiers of tartan fabric separated by ruffled lace inserts, creating distinct topographical ridges and volume.
    The main body is constructed from a matte woven fabric in a classic tartan plaid pattern, featuring deep crimson red and black blocks intersected by thin white lines. This textured surface contrasts sharply with the smooth, lustrous sheen of the wide black satin ribbons used for back lacing. Intricate black floral lace trims the neckline and shoulder straps, while ruffled tiers of the same delicate lace separate sections of the skirt, adding softness to the structured geometry. Small silver metal eyelets line the corset edges, providing metallic accents against the dark fabric. A layer of sheer white tulle is visible beneath the plaid hem, adding a ghostly translucency and extending the volume downwards.
    Mütze 1:
    a vintage dark brown distressed leather newsboy cap (flat hat). The subject features a bulbous, segmented crown constructed from multiple soft leather panels, creating a volumetric topology with natural creases and folds that indicate pliable material depth. A distinct horizontal leather band encircles the base of the crown, featuring a buckle-like strap detail on the side secured by a small metal rivet, adding physical relief against the smooth upper surface. The short brim curves gently downward with a rolled edge. The texture is rich waxed leather with visible grain, subtle scratches, and tonal variations ranging from deep espresso to lighter amber highlights. Thick, contrasting tan stitching runs along every seam, creating raised ridges that emphasize the structural geometry.
    Mütze 2:
    A rich brown leather military officer's cap. The hat features a soft, slouchy crown with visible creases and folds indicating pliable material, contrasting with a short, structured stiff brim (visor) at the front. A horizontal leather band encircles the base of the crown, secured by a matte black rectangular buckle on the side. On the upper left front panel, a detailed silver metallic emblem depicts an eagle with spread wings clutching lightning bolts or arrows. The hat includes an adjustable strap mechanism visible along the side/rear, featuring a circular silver-toned metal stud and sliding hardware for sizing. The surface texture is pebbled leather with a subtle sheen, highlighted by fine stitching running parallel to the seams and edges.
  • Modenschau, Maestro? :huh:
    Ok ...
    ohne Karos für besondere Anlässe (z.B. Beerdigung, Testamentseröffnung, Scheidungstermine ...);)
    ____________
    Freiheit den Organen - weg mit den Korsetts! :DD
    17.2 mm für Bastet  <3
    </> drücken ist guuut ;)
  • na dan greifen wir die nähmaschine und zaubern ein bischen: ein echtes Stück Avantgarde-Couture.
    ki qwen2512
    prompt:
    A hyper-realistic full-body portrait of a young woman with intricately braided, up-swept red-orange hair, wearing a complex, avant-garde outfit against a seamless studio background with soft, diffused illumination.
    She wears a bulky, sculptural zombie horror-style hoodie made of distressed, pale necrotic green-grey felted fabric with a weathered texture. The deep maroon hood frames her face, while the central chest piece is dominated by a large, inverted V-shape of viscous, dripping crimson and orange paint. At the apex sits a protruding, matte grey branching vein structure radiating outward, converging at a small bone-white skull embedded in the fabric. The long sleeves feature irregular rips along the forearms revealing raw dark crimson simulated flesh underneath, ending in solid brownish-black cuffs, with the bottom hem heavily tattered into asymmetrical downward-pointing black spikes.
    Beneath the hoodie, she wears a floor-length skirt anchored by a high-waisted black bodice with deep, radiating vertical pleats at the waistline. Below this top section flows a voluminous cascade of semi-sheer, radial vertical panels transitioning in color from cool blues and purples on the left to pinks, oranges, yellows, greens, and earthy browns on the right. The skirt consists of multiple layers of lightweight organza fabric with subtle ombre effects and faded vintage floral motifs following the drape. The waistband features a scalloped edge with intricate gold and rust-colored floral embroidery, ending in an uneven, tiered hemline with soft, wavy fringes. The lighting highlights both the glossy sheen of the wet crimson paint on top and the translucency of the rainbow panels below, casting deep soft shadows within the pleats for vivid three-dimensional depth.
  • Duell der Modeschöpfer? Nun geht's los ...
    Die Frisur hält nur bis der Nachtclub schließt. :DD
